vanquish
Bridging/Strapping
I read the instructions in the FAQ's section but i'm still somewhat confused.
If i have (2)saz1500s strapped together i will still be getting a (1ohm) load correct?
I am going to be running (2)FI BL - dual 1 so will run into a problem strapping these two amps together for my setup? Should i look into purchasing dual 2's instead
why not run one to each driver?
he's probly trying to get more power to each BL. BTW you dont want more then 1800 to each BL . id suggest you run each of each amp.
I guess that would be the easiest way my only concerns are try to set the gains on both amps so they match.
I'm still curious about bridging/Strapping the amps just for future reference.
(2) 1ohm mono amps strapped would be a 1ohm load or would it change to 2ohms?
You want to strap the amps at 2 ohms so each amp sees 1 ohm.
Weather you strap or run the amps independantly you are better off with dual 2 ohms subs. Run the coils in series if you strap or in parallel if you run each amp seperate. If you are worried about getting the gians to match use a test tone and a DMM.
