brent338
SunDown 3000
need new amp.
quick question....
how would it hold up @ .7 ohms?
with, 230A alt, Yellow top under hood, Kinetik 2400 in back, 1/0 under hood & back, second run there but not hooked up,
It's either .7 or 2.8, two Quad .7 coil subs... TC-3000.
I could do two 1500's @ 1.4 ohm each I guess...
but I rather like the idea of one big amp...
Ideas?
It should be fine. .7 ohms is ~1 ohm with minimal impedance rise.
would be a great set up except you will be waiting a while to get a 3000d, they are out of stock until sometime in August for a new one. You might have some luck with http://www.db-r.com however.
Although 2 saz-1500d's strapped would be well under warranty and similar power.
That and the coils are rated at 1 ohm impedence, DCR is just .7 ohms.
Also, doing the math in my head there is no way to get 1 ohm, you can only get 1/8 ohm, .5 ohm, 2 ohms, 4 ohms or 8 ohms.
Indeed - 0.7 DCR is a normal 1 ohm load. Totally fine.
Chris @ db-r.com has a few refurbished 3000s (2 I believe).
1.4 (2 ohm) would be perfect for strapping.
But how can you wire 8 1 ohm coild to 1 ohm, 4 1 ohm coils will work out to 1 ohm, double that you either have to have 2 ohms or .5 ohms, or the other combos i listed.
Yes it would, 2 SAZ-1500Ds and there ya go.
yeah, I just talked with him... might go that route.
just wanted to make sure the amp could take it daily...
BUT IT IS IMPOSSIBLE TO WIRE IT LIKE THAT!!!
Would be a 10x better choice to do 2 1500Ds strapped.
Oh, thought he just had one sub.
For TWO subs you need two 1500s as it will be 0.7 per woofer final load.
Old TC Sounds site...
http://web.archive.org/web/20070224172836/....com/tc3000.htm
can be wired...
1 sub; .35, 1.4, 5.6 ohm
2 subs; .7, 2.8
I know this for a fact, cuz we just put a meter on each sub, wired to the 1.4 diagram...and they read 1.4 ohm. add them series and we got .7 ohm, in parallel netted 2.8.
I just want to know if a SAZ3000 can do .7 daily with my electrical without having problems...
yeah I could/would do two 1500's if I need, but I dont.
can be wired...
2 subs; .7, 2.8
You got those backwards, parallel is low resistance, series is high resistance
Honest mistake, atleast you learned something today right?
I really know that, just typing too fast... A very long/stressful day.
but 1 lesson learned also... no Orion 2500d @ .7 ohm.... lol.
o.k.
did some power test research.
getting kinda ancy now...
A SaZ3000 @ 1.4 ohm, 10.75 volts; gets 3200 ish watts.
@ .7 ohm, 14.5 volts; gets 5200 watts, while going into protect.
So I'm I right that guessing 4100 watts on a 12 volt system, @ .7 ohms to be an accurate estimate?
any tests done at that voltage & ohms?
that doesnt sound right... if it is i really need to hit up sundown to see what i can do to get one i thought ~5200 was the 16v number
Either way... it's plenty of power.
TC Sounds had several SAZ-3000Ds and 1500Ds on hand that they used to test their products with in vehicles.
Interesting, huh ? :)
