Was drivin around testin out new speakers and was turning up the volume, and when it hit 29/35 everything just shut off. So i figured I blew a fuse. I checked the fuse box numerous times and the fuses are all fine. Took out the HU cuz a buddy said there was a fuse behind it... nothing... I have no clue where to go from this point.
Edited by LWKING
that's not really enough info.
Turn your stereo back on and see if the power light on the amp comes on or if the protect light does.
If neither come on, check the fuses on the amp itself if there are any.
Also, check to make sure the power wire, remote wire and ground wire are all connected to the amp and the opposite ends are all properly connected too.
lol, 2nd fuse box under the hood, still a problem tho. Ive blown it 3 times already on accident. (finger slipped haha) is there a way to stop it form happening or do i just have to deal w/it?
You sure your finger was slipping and there isn't a short in your power wire somewhere? I would check that out asap.
