Smondo17
2 Way active Setup for Friend
Title explains it just wanted to run it by some people on here. Wanted to keep it pretty simple and not overly expensive. Going with a an alpine 9887 headunit running active. Sundown 100.4 amp, Sea CA18RNX mids, and Seas 27TFFNC/G tweeters. Crossing tweets at around 2.5k and mids around low 2k. Question that i just want to make sure is can the CA18RNX mids run up to the 2k range?
They will be fine playing to 2k :)
Dont feel like starting another tread but friend is looking to get a 12inch Icon Sealed running off a sundown 1000D. Optimal box that they suggest is 1.2 cubic inches. Would there be any benefits to a bigger enclosure? Also what are the differences between the 10 and 12. More cone area for the 12 more output? does one get a little lower? any SQ differences?
Not that you'll be able to audibly hear a difference in SQ. You may hear a bit in SPL, but not enough to make you *gasp*.
A benefit to a larger box is running less power. You could always use the recommended box size and then stuff it about half full with polyfill. That should get you an extra .2^3ft of "space".
