toolskizm
Fi Q information on site
Just curious if there's a reason the Fi Q series isn't showing up on the website...Either way, could someone possibly give me the specs on the 12" sub. I need the detailed specs so I can input the sub on WinISD to attempt a box design.
Ok, thanks for the info. Is there a way i can get the detailed info on the Q12 with Bp power? Or would I be ok putting the SSD 12 info into WinISD?
for example:
Fs: 27.0 Hz | 26.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.60 | 4.71
Qes: .52 | .49
Qts: .47 | .44
Mms: 192g | 201g
Cms: 0.18mm/N | 0.18mm/N
Sd: 480cm^2 | 480cm^2
Vas: 58.7 l | 58.7 l
Spl: 85.3dB 1W/1m | 85.3dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Xmax: 21mm
Rms: 800W
Sealed box: .8-1.6 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500
Don't have it right now where i'm at..
The box recommendations do not change...as it is just an extra spider and an aluminum plug.
Stick to what we suggest..
Try clicking the link Chris, they took them offline.
Your correct. Sorry about that, I didn't look into it further as I should have. :D
