sundown88
my system
Wut I Run...
For Subs I Got :
2 12" Cerwin Vega Stroker Pro's
Each Push 2500-5000 Watts
For Amplifiers I'm Running A :
Sundown SAZ 3000d
To Each Sub
Using Phoenix Gold :
2 6 1/2" Mids
2 Tweeters
2 Crossovers
Using Kicker Hyperflex Wiring
Powered By A :
Kinetik Hc 2400
Ill Upload Pix As Soon
As I Can Get A Hold
Of A Camera...
Later Daze
Blast Sum Bass...
Welcome!
1 HC2400.. that's it?
MAn!
I'm about to install about 5kw in mine and plannin on running 1 of those plus 2 more kinetiks and 300A alt.
man.....id say get some electrical goin!! post in here to get some good advice on that. But you're really hurting your system if you have all of those watts and only 2 kinetics. Is everyting else stock??
I try 2 underwatt everything a little bit
i tend 2 use exccesivly.
trying 2 keep it kool
how many battery watts would u use for my set up???
seriously, i think 2 hc2400s with a 300A alt should do it for ya on an average level.
3 hc2400s would put you above recommendation for batteries.
You need some more batteries. What you got there now isn't enough.
meh, I hope your installing skills are better than your English.
DUAL....... are you kidding me.
o.k.
just ordered another hc2400
3 should do the trik
u guys are killin me...
lol
i suk at typin man...
i type fast.
n e ways
my duel deck???
not a good match...?
i got the
duel XDM6830
Model It's...
200 watts
N E Other Suggestions 4 a DEck...?
If
You
Want
People
Here
To
Answer
You
Have
To
At
Least
Make
An
Attempt
To
Type
Normally
Please
Do
Us
All
A
Big
Favor
And
Try
Deal
as of now
(b 4 I Wire N My 3rd Kinetik)
Im Runnnin 2 hc2400's
& 1 300/350 AMP XSVOLT SPL Competition Alternator
as of now
um if your planing on using that for a daily i would not use that alt there ment for comps only if you use them in a daily and drive around and bump for long periods of time that alt will over heat and fail i would recomend looking into a exsessive amprage or ireggi alt ohio gen is good as well if you want to go with powermaster which is good as well dont get one of there comp alts look into one of there high output daily alts
from powermasters site
"The SPL alternators are specifically designed for trailer only extreme competition vehicles. Because of the radical design, output at idle is usually 0 and because of additional heat created; these units should not be operated at full output for more than a few minutes. In some cases, SPL units can be custom installed as a second alternator to the original unit for street applications. However, caution must be taken that only short-term loads are sent to the SPL alternator."
Edited by dsgfierce1
o.k. thanx 4 the prewarning
what alt. would u use
on a system like mine???
Excessive Amperage 300amp alternator ?
or
Iraggi 300 Amp Alternator ?
which will keep volts (More) steady
for long periods of use?
best for SQ?
Typing normal will get you SQ answers, acting like a fool will get you made fun of :(
6kW, multiple component sets, a competition alternator, "blast sum bass"...
And best SQ?
This just keeps getting more confusing as it progresses :)
or
best for SQ?
well i run 2 SAZ-3000D's on a ireggi 300amp alt so i guess i would go with ireggi lol but that choice is all up to you
or
best for SQ?
oh also i would get powermaster batts as well if your gonna run an ireggi alt i beleave that his alt puts out a higher voltage which tends to destroy the kinetiks since they can only accept a 14.3 volt charge for a short time powermasters can accept 15.0 volts from what i have been told :) + both sundowns site and dominick ireggi both recomend them for use with the amps/alt as well as many people on this forum chose them over kinetik so thats enuff to have me convinced lol
Welcome to SSA, that is a hefty list of equipment you have there.
