I'm just wondering what are the pros/cons of using a dry cell battery, than a wet cell battery. I need to get a couple of batterys and need to know the differences between the two so i know what to buy.
A wet cell lead acid? Like the kind you use under your hood that lets off toxic fumes that kill brain cells?
lead acid has higher resistance so takes longer to charge and longer to discharge i believe.
Is not as safe as AGM batteries that's for sure.
HIGHLY do not recommend installing them in any part of cabin or cargo area. IF somethin bad happens... terrible mess and hopefully no damage.
but with a wet cell you don't have to use lube, you know? you know what I'm saying? *wink wink*
oh, oops. this isn't off topic. i'm dirty.
I'll Lube you in a minute!
I mean... :wrongforum:
