i went ahead and ordered 2 SAZ-1500D's. I had a stock battery but i purchased a Duralast Gold Yellow Top before i started on my system. I got a 200 amp alt coming and i purchased a Kinetik HC1800 to go in the trunk. IS this enough? i wanted to do the big 3 upgrade but i wouldnt know where to start much less what to do. is adding the extra bat and changing the alt enough?
What ohm load will you run the 1500's at?
i have 2 RE SX12D2's. 2 ohm load.....
So strapping the 1500's then? You're right on the edge if you strap them. If you run them each at 2 ohms, you should have more then enough current.
I was gonna strap the 1500's. Think i'll be okay?
You should be ok for everyday. I wouldn't be cruising around at max (clean unclipped) volume if I were you.
I dont intend on beating it that hard. Honestly, I just want the ability to call on that kinda power if i need to. Say if i enter a car show a decide to take a crack at a competition I got the power at my fingertips.....
Edited by Superman_69
