rollerdj
help with HT sub box.
i have a OZ ME10.2 i'm going to use for my HT sub. i'm wanting to incorporiate (sp?) it into a end table since i don't have one for eather coutch. if i do sub and port both pointing down, how far off the ground should i have it? i will be also going at about 1.25 cubes, what should i tune it to?
I'd like to see at least 4" of clearance, more is even better. As for the tuning, for HT somewhere in the realm of 14-20hz would be fine. 18 is probably a logical starting point.
Usually about 3-4 inches. Do you have the parameters of the sub? You would normally want to build large and tune low, if you can. Doing that will allow you to pick up some of the ultra lows that exist in today's movies.
Best,
Mark
Edit: Ha! Sean beat me to it..
cool. thanks guys. pics will follow sometime in the next couple of weeks for my first audio related build log. :D
:woot:
