kermit5327
what is this
ok so i found these in my garage and i have no idea what the hell they are could someone help me out i think they are like crossovers or something but i have no idea
it says infinity reference on it
passive cross over
Each passive crossover set is designed to work for a specific pair of speakers because diffrent speakers need diffrent crossover frequencies.
You can use it with other speakers, but they will not perform as good as possible.
I believe "IN" is pretty basic. It's the input.
You connect the mid-bass to the "WF" terminal.
You connect the tweeter to the "TW" terminal. the -3dB terminal is used for the tweeter. You connect the positive wire either to the TW+ terminal or to the -3dB terminal. The latter terminal is used to provide a lower level for the tweeter in case it's too loud for your tastes.
ok thanks i plan on installing a set of infinitys into my cvic sedan. i have been trying to think about how to run the set up that i want but i just cant figure it out... maybe one of you guys can help me out here. is what i what to do is have a set a tweeters in the A pillars and 6 1/2's in all 4 doors and in the trunk because that is the only thing that fits stock. but i cant figure out how to wire the speakers to the rear doors with out it sounding distorted. by the way im really wanting to this off of a stock honda head unit
pop the cover off.. and you will see the tw sw an the in...
althought u will get a better sound IMO if you run it on an amp..
