dsgfierce1
alternator
So i got a quoat from EA for a 300amp alt but he said i need to mod the bracket to beable to install it i was wondering what would that consist of? Any one had to mod theirs befor ?
you need to have special custom made brackets to be able to mount the large alt in the stock position. with that being said, instead of mounting the alt in the stock mounting holes, the alt will mount onto the brackets, then the brackets will mount into the stock location of where the amp used to be sitting at. you will need to find someone who will be able to make you these custom brackets. along with that you might be needing different lenght belts to be run in your car.
i bought the biggest amp he had that was a direct bolt on so i would not have to modify mine. i know of nobody down here that would be able to make me custom brackets. so :/
humm well in that case would a 200 amp or be good enuff for 2 SAZ-3000D with a yellow top under the hood and 4 powermaster D3100 in the back ? or should i look into finding someone that can mod my bracket
I cant wait to hear this one! I am going to be running probably the exact 2 amps in a soon-2-be setup and need a new alt first. Killin two birds with one stone on this post :))
doing custom alternator brakets are not for the faint harted. Look at you bay very carefully and think about it before doing anything. Check sizes brainstorm and hopefully u can get it working
thats alot of battery for 6000 watts
well how many should i run? i have seen people with less watts running more batts then im planing on running but i also have 8 kicker 6x9s and 4 kicker tweets that i will be running to 4 more 200watt amps so alltogether about 7000w total.
are you gonna do spl or just street beater?
im going for an insainly loud daily. I don't plan as of yet to enter any comps with it lol. but you never know.
i would run all those cells your plaing too.. get the biggest alt you can with out modification... and then have 1 run of 0 gauge from each cell... stright to the alt.
thanks for the advice :drink40::neil:
Whew, 1 run of 0gauge for each cell....that is a whole lotta wire being ran, have fun :)
Yea but if your gonna invest this much into a system might as well do it right the first time. That way you dont have to go back later to fix prior mistakes :)
k nate at EA said that a 225amp is the biggest he can make me for a direct bolt on so im gonna go with that and 5 powermaster d3100 in back and 1 yellowtop up front that should be good for 2 SAZ-3000D right?
IMO you have it done well... the only problem i see is that at idol... your alt will only be putting out like 90 amps.... but with that many cells you should be able to stand and show off for a few mins.. but u may have to keep a foot on the fuel pedel
thanks big john you have been a great help :drink40: so then its set welp one more month and ill be getting my loan from the bank and ordering all my stuff at once once i get it all setup ill be sure to post some pics
ya once in a blue moon bigjon will have something helpful comming out of his mouth..lol
:neil: lol yeah he replyed pretty quick to my posts, almost right after i posted them.
oh and one more question wile im thinking about it! you said at idol my alt would be running less amps.Which i was awear of allready but the question is would more batts solve the gas pedel at idol prob. Or should i not event worrie about it and just run 5?
well i talked to dom today on the phone and he said that he could make me a 300amp alt that would be a direct bolt on so im just gonna go with him since he makes the biggest alt i can get :)
