JoshHd6
Amp For 2 18" BTLs
If that includes electrical you are going to need more money.
electrical is takin care of..
Application and desires would help as well.
are they d1 or d2 and how much power you looking to put to them...................
dual 1s..daily system so 2k a piece would be nice...its in a jeep..
800...... wow thats a budget.... saz 3000d... get a used one.
JoshHD6 - you in the same city i'm in, gotta hear it when you get it all setup.
refurb saz-3000d
2 opti2000ds strapped @1ohm
4 refurb opti1400ds
you can get all that for under $800
refurb saz-3000d
4 refurb opti1400ds
where are u located in louisville? everything will be in by the end of april..
personaly I would go whith the saz-3000d (refurb)for around $800..............can the jeeps elec. system handle it thow..........the 3000d is very eff. but the better the elec. backbone is the happier you will be in the long run
these are a little underrated, and on sale since the new line is coming out... awesome amps and a great buy!
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=3195
for something new I would do that, if not then do either one sundown 3000d refurb, or two 1500d's strapped.
Might be able to find a RF T4k for close to that aswell
http://www.stevemeadedesigns.com/board/ind...15609&st=40
Power accoustic 5500s. one on each amp at 2ohms would be good.
You could find a memphis 4k, RF T4000, or several others used for that price, or around 1000 new if you search. The termpro forum is down right now, but they have AB 500.1s pretty often.
A little more than you're budget but you can find used ones pretty often.
http://cgi.ebay.com/Hifonics-Goliath-5000w...1QQcmdZViewItem
Good luck
http://www.*****.com/board/ind...15609&st=40
Good luck
thanx for the help guys..ill probably go with the sundown..heard it will do close to 4kw with good eletrical..plus my 200 amp alt will be here soon..and shizzon where are u located in louisville?
well i do believe that is your best bet but the saz-1500's did peak more at higher voltage i believe
They do slightly but in this case at 1 ohm nominal load before impedance rise a pair of saz-1500d's would be strapped and running .5 ohm nominal impedances each voiding the warranty for a couple hundred watts.
