denalilvr
SAZ-3000D
hey guys, what do these put out at 1ohm on a electrical system of 14-15 volts?
also 1 more question if you dont mind..do you think a 300 amp alt from EA and a yellow top under the hood and 2 Kinetik HC2400 batteries in the back will be enough juice for the saz-3000 to its potential and a sundown 4 channel amp?
heres some info on the kinetik's incase some dont know them
Kinetik HC2400 Power Cell. MOST POWERFUL audio cell anywhere, PERIOD! Used in the loudest vehicles in the world and boasting over 180dB when used in competition. This bad boy has more current than power cells twice its size. If you want the BEST, this is it. Providing thousands of amps at near dead short, this power cell performs best when abused.
* Weight: 69 lbs.
* Ah: 128
* Amps: 2600
* Dimensions: 13" x 6.7" x 8.5"
* AGM Technology
* Sealed Non-Spillable Design
* Mount In Any Position
* Ultra Low ESR
* More Plates For Stronger Energy Density
* Higher Voltage Under Load
* Tightly Packed Cells
* Superior Heat & Vibration Resistance
Edited by denalilvr
with that combo of alt\battery you will have no problems thats alot of juice backin up the 3000
That electrical system will be fine. Assume over 3000 watts if you can actually maintain 14v, but that is unlikely even with a 300 amp alt since it usually won't be putting out the full 300 amps.
thanx for the words folks..the guys over at ssa quoted me a great price on the 3000 model and anyone would have to be retarded to turn it down..so looks like i'll have one comming to me in about a week or two..again thank you everyone.
