hayes55987
few subs to compare
hey guys. Trying to find a new set-up here (sub set-up) and am looking around at my sub options! Currently I am running an 18" BL in a 5.5ish box @ 35Hz I think. It is pretty dang loud...but I am starting to go away from SPL based to subs that are able to reproduce the sounds a bit better. I have recently acquired a pair of Adire Koda 6.5 components and am hoping to blend things. The BL would pretty much destroy any midbass that would be output with them and I really wanna do a proper(ish..bear with me guys haha) set-up of an actual "sub" crossed over at 60Hz or so and then hear some real midbass.
Here were the subs that I was looking between. Currently I have a JBL amp that puts out between 1200-1300 RMS @ 1 or 2 ohms. Its the older BP series. Some of the subs I'm looking at that definitely don't need this much power, so I will either have that as max power (more then enough really), or I can downgrade if I need to. But for my comparions, just assume that I would be powering all of the subs at their "optimal" or above optimal RMS ratings. I'm worry about the amp later. I also have upto 5.5 cubes to work with, which is way more then enough for these so the boxes would all be built to the recommended/optimum box sizes as well. Here are my choices! lemme know what you'd pick
From Acoustic Visions: Exodus Audio Tempest-X
From SSA: A 15" D1 Icon
From Ascendant Audio: A 15" Havoc
From Sound Splinter: A 15" RLP
I had also looked at the 10" Rl-i, but I had guessed that the RLP had similiar sounding but with a bit more SPL on it, and seeing as space wasn't an option, I had counted it out. But let me know if you think I was incorrect in doing that!
Hopefully you guys can help me out!
I should have also added that I had considered a 15" Fi Q
but seeing as I had the BL now I had almost wanted to try out a different brand
If the Q is really the best sub you think though let me know!
the Q sounds alot better then the BL to me, but in that list you put up there you really cant go wrong, i havent heard the havocs yet but have been told they are like Q's if thats the case then they should sound pretty nice. The SSA Icons are a great deal especially for the money, i put one on 600 rms and it sounded great enough for me to plan purchasing 2 more of them. The RL-P sounds decent as well, im just not a fan of TC made products but thats not to say they arent decent.
lol darn it! Thats exactly the problem I had
i've found tons of reviews on these subs but the problem is that they all say buy me! I can't make up my mind.
Can someone rank them for me maybe in like terms of best sounding? and best output?
There is no better or more output definitively in the group, but they are definitely different. Considering your goals and past, I'd lean towards the Icon out of your list.
