What kind of wiring am i going to need, assuming 1/0 gauge?
So far i have:
SUB: Fi 15" BL
AMP: saz-1500
ENCLOSURE: 3.8ft^3 @ 32 hz
i have no clue how much and what kind of wiring i am going to need.
How much depends on how much you need. Grab a measuring tape and figure out your path from your front battery to your amp. Buy the amount plus a little extra (2-3ft).
1/0awg would be ideal, especially in case you ever upgrade.
Thanks that makes sense. The guys at this local shop will install everything for around 180.00... should i give it a try or just pay them to do it? i might stick to the safe side and let them do it. Only problem is they don't have any 1/0 gauge wire at this shop he said i'll have to buy it myself :Doh:
What other kinds of wires/fuses would be sufficient for this setup?
Wire = wire in most cases.
Weldingsupply.com can outfit you with 1/0awg. You'll also need an ANL fuse holder and 250A fuse.
I wouldn't pay a shop to run wire. Its not hard.
So i just found a ANL fuse holder w/ 250A fuse. All i need is the wire
any other (recommended) websites that carry good wire?
