caddyon20s
18 BTL FULLY LOADED GOOD AMP FOR IT??
Hi its me again i have another question about what amp should i get for my fully loaded btl not so expensive or who was a btl 18 and what amp are they using thanks.
"not so expensive" is not a budget.
You should know better by now. What is your budget, what voice coils does the BTL have? Hopefully you got a DVC1 BTL.
The optimal match at this point is the SAZ-3000D if you have the coin.
x2
why do people buy subs w/o planning ahead to figure out how they are going to run them???
i mean i'm not trying to be a dick or anything but you know it would seem logical to overlook all your options before buying things.
Edited by fbi90909
i know what ur saying and i know what i need but im just asking for some adivice,, i know a rockfordfosgate t20001bd amp would work great and some batteries wont hurt, but i need some different brand amps just as good or better maybe than the rockford fosgate amp for the same price or maybe less, and i got a fuly loaded btl becuase i know it would be a super sub.
Edited by caddyon20s
You still haven't answered any of the pertinent questions that need to be answered before anyone gives you a recommendation.
Then your looking for an amp that'l do 2kw at 1ohm...plenty out there :).
Thanks!
-Nick
If you google 'ampguts' you'll find a huge list of amps. Or ebay it.
I'm just going to list a bunch of amps that will get the sub moving well between 2-4000 watts, and you can decide what best fits your needs.
Hifonics 2607d
Hifonics Thor
Hifonics Colossus
I.A. 40.1
Lanzar Optidrive line (not sure of the models)
MA 4000
Massive 3000
Memphis 2000
Memphis 4000
RF 2000
RF 3000
RF 4000
Sundown 3000
and the list goes on and on. There are so many out there, and price will vary greatly from seller to seller, and if you're willing to buy used. If you're willing to buy used equipment check the termpro f/s section, the one on this forum, or even ca.com.
Hifonics 2607d
Hifonics Thor
Hifonics Colossus
I.A. 40.1
MA 4000
Massive 3000
Memphis 2000
Memphis 4000
RF 2000
RF 3000
RF 4000
Sundown 3000
the Hifonics 2607d amp is the cheapes.. how does it perform?? would it be a good amp or not?? thanks.
I wouldn't touch it with a ten-foot pole.
Out of that list, I'd pretty much narrow it down to the Incriminator, Rockford Fosgates and the Sundown. Out of those, whatever you can get the best deal on/best support with...
I listed a bunch of amps- some are really good- and some are budget. I have a 2006d that I didn't have any problems with.
i found these ones i like the price let me know what yall think and wich one is the best of all..
http://cgi.ebay.com/NEW-POWER-ACOUSTIK-A30...1QQcmdZViewItem
http://cgi.ebay.com/NEW-SOUNDSTREAM-PCA200...1QQcmdZViewItem
http://cgi.ebay.com/MA-Audio-HK802SX-Amp-4...1QQcmdZViewItem
are these any good or should i just save up and get a t20001bd by rockford fosgate???
  ford302redneck said:
Another cheap options, even tho I hate to say it is the New Audioque AQ2200d.
I just saw that amp the other day. I was trying to find some info on it.
What do you have against/for it? Sounds like a good, cheap amp if it's like their other products.
would this hifonics amp push my btl 18 good or is it a bad amp??
HIFONICS BXi2607D D-CLASS AMP 2600W MAX "BRAND NEW" 369 shipped off of ebay
Brutus Series 1-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 850 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2600 watts x 1 chan.
Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
Highly efficient Super D-Class amplifier circuitry with over-sized MOSFET Output
Dash-Mountable Bass Remote Control Included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 45)
Twin-Turbo Torroid Coil Design
HSMD Hifonics Surface Mount Design
Balance Line Inputs for 18-Volt line drivers
Preamp RCA output
DC, Short Circuit, Overload Protection Circuitry
Feature #6 example: Maximum Dynamic Headroom (MDH) power supply
Hifonics New Illuminated Heat-Sink Design With Blue LED Light Pumps
Gold-plated screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 15 Hz)
Frequency response: 2-250 Hz
2-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
1-year Sonic Electronix warranty
Amplifier Specifications:
Amplifier Class: D
Number of Channels: 1 - Mono
RMS Power (4 ohms): 850 watts x 1 channel
RMS Power (2 ohms): 1700 watts x 1 channel
RMS Power (1 ohm): 2600 watts x 1 channel
Bridged RMS Power: Not Bridgeable
Peak Power Output: Not Specified
Minimum Impedance Unbridged: 1 ohm
Minimum Impedance Bridged: N/A
THD at Rated RMS Power: .1%
Speaker Level Inputs: No
Amp Preamp Outputs: Yes - 1 pair
Built-in Crossover: Low-pass (LP)
High-Pass Crossover Frequency: N/A
Low-Pass Crossover Frequency: 35 - 250 Hz
Subsonic Filter: 15 - 35 Hz
Signal-to-Noise Ratio: 95 dB
Channel Separation: N/A
Bass Boost: 0 - 18 dB
Bass/Gain Remote: Yes
Fan Cooled: No
Fuse Rating: N/A
Warranty: 1-year
  caddyon20s said:
MORE OPTIONS MAYBE?? THANKS EVERYBODY..
Autotek mm3000.1?? The Hifonics BXI line is meh, there's definately better out there.
Edited by plushDJ
no theres this guy selling it on the forum realmofexcursion but i was wondering if it was good for my fully loaded btl
