bigjae1976
Chaos 12 on a Sundown SAE-1000D
Just finished installing a Chaos 12 in 02 Ford Mustang coupe. Running off a SAE-1000d in a ported box. I forgot the exact specs of the box but its around 1.8 cu ft tuned to 34hz.
Metered at 137.0 on a TL in the kickpanel.
Sounds pretty damned good too!
Sweet.
I did the exact same in my 94 Stang.
So I guess, I know how loud it was. hehe.
I had a 12 Q and a SAZ-1500D.
I have a pic...I'll post if later. Just too lazy right now.
It is a Chaos...not a Havoc. Its a small step down from a Havoc. The magnets are shaped just like an Fi. A very nice sub for ~$300.
No pics of the sub...forgot. And the guy is on the way to Minnesota or some crappy state up there ;).
My bad.
I'd say the chaos is a pretty damned good sub. The power ratings do seem a little convervative...it can handle a little more.
To be honest, the extra $100 to step up to the Havoc is WELL worth it if you have 1000+ watts.
Edited by bigjae1976
what was your peak frequency?
IIRC - 42hz was the loudest tone. I'm not sure if that was the true peak or if the system voltage starting dropping above that. I started at 35 hz for about 10 seconds in 1 hz intervals. So I was running it pretty hard for a minute or two. The car had a stock electrical system.
