04yzfr1
Vent for BTL'S
2 18in btl's fully loaded
12 cuft
tune 34hz
Port
wide 18.5 in
height 5 in
lenth 10 in
That is 185 sq in
12 x 15.42 = 185.04
right? thanks
will have to re think it ..... thanks
what do you think on port...
Edited by YZFR1
if you have calculated all displacements properly including port displacement and wood thickness of port displacement, a port of-
18.5" wide
10" tall
26.4" long
would work for 34hz.
The dimensions are for a slot port(one that shares walls of the enclosure).
It is important to know this because if you make a port where the port doesn't share the walls of the enclosure then the beginning acoustical length will be shorter resulting in a slightly higher tuning, probably no more than 1-2hz though if you are inaccurate.
Thanks i dont know if i was going to use a slot port or porting it out just below the subs.
looking for ideas though, what would perform better just getting read to start the port and ideas can be changed, please let me know
well, the best port would be flanged at both ends and that's typically circular ports.
If this is for daily driver, it really doesnt matter. You apparently have enough space to do a slot port so buying parts for flanged ports may be a waste of money.
cool thanks think i will do the slot port, this is a weekend car only , and this is also a wall with one chamber
