caddyon20s
fi 18btl can u get extreme leads??? flatwind??
hi i have a quick question, the btl line dont have extreme leads like the bls??? I AM A be getting a fully loaded btl.
Edited by caddyon20s
they are starting to use leads woven into the spider, cause too many people are snapping leads from user error. the woven leads should be better though.
so do they come with the flatwind standar??
taken off the website
"The BTL Series does what others cant. It allows you to tailor your subwoofer for your exact extreme SPL needs. Starting with our standard double stacked motor and 8 layer flat wind voice coil, you can tweak things with a variety of options. Need more power handling? Add a chamfered pole or axial cooling channels. Need incredible Xmax to feed your 160dB at 20Hz obsession? Add a third magnet and our extended length coils (26mm of Xmax). With over 20 different options to choose from, we can build the exact sub you need to fuel your SPL fire."
when the btl had the regular tinsel leads, they came stock with the "extreme lead"s. now they are being woven or sandwiched between the spiders, so im not sure what they're doing now. the coil is already flat wound as well.
The leads aren't woven into the spider...they are run between the spiders. Very different things. ;)
You can't get them...they're already included with the BTL..but we're using woven leads now...so you don't need them.
Thanks!
-Nick
OK OK so who is telling the truth
i speek deh truuff
lawl.
