bobc04
is this possible?
k, i was thinking... i have a Re Audio SX Dual 2... can i run a sundown audio 1000d to each voice coil. so it would be one 1000d going to one and then another 1000d going to the other. someone let me know
Yes it is, but it would be easier to set up by strapping the amps at 4 ohms.
he's right. You would get the same output power either way but strapping is safer because there is less chance of an error during setting up an amp per coil.
You could, but you would be better off just buying a 1500D for the power that you'll be getting at 2 ohms from the 1000D.
x2 getting a single amp to power the sub is much easier. I would think the 1000d would push the SX perfect. I installed one with bout a 1000 watts an it slams like no other.
