mclarengts
Just ordered A BL
You will see it when you remove the tape from the box and open the box up.
There are multiple ways of doing this-
You can get a knife, any small blade will work and use the "cutting side" of the knife to cut the tape that is holding the box shut. Just gently run it across the underside of the tape at the ends of the box.
A safer way is just to use your finger to pull the tape back at the ends of the box and rip the tape off.
Regardless of how you open it up, it will not void the warranty unless you burn the coils up during opening the box or the spider gets ripped off because you thought the sub was inside the BL... :o
Anyway, good luck with seeing the sub and post a vid of UPS delivering it because i havent seen any in a while!!
Edited by shizzzon
