vanquish
Need Box Design Help
Just placed an order for my 15" BL
Anyone willing to help me with a box design?
Trunk Dimensions Estimating: 36 x 36 x 18
width = 36 in.
length = 36 in.
height = 18 in.
Edited by lost
What would you like it ported to? And how much power are you running?
I'm pretty much clueless when it comes to box specs, i tried to read and learn but its not clicking for me.
Ported to 32-33htz idk how much of a difference between the two would be.
Yet to buy and amp looking @ 1500RMS though
How big is the trunk opening? Can you actually get a 36 x 36 box in the trunk?
I replied to your PM. . .
You could do this:
Just shy of 4 ft^3
36" wide x 18" tall x 17.5" deep
16.5" x 3.5" port, 29.5" long. 32-33 Hz tuning.
You could do this:
Just shy of 4 ft^3
Hey thanks for the diagram, that helps alot with a visual
I might be pushing it height and width wise but i think it'll fit.
Flared Ports vs the one shown here?
besides the fact that you stated they need less port area.
Could you draw up something with flared ports?
Im considering this option.
If you did a pair of the precision port 4" flared ports, they would need to each be 14.5" long.
If the sub and ports will face rearward, then the box needs to be at least 19.25" deep for rear port clearance.
You could do 16.5" high x 30" wide x 20" deep with a 1.5" thick front baffle (external dimensions).
Sounds good.. but where can i buy theses ports from?
you have a few websites for me
Edited by lost
Hate to bug but could you draw me up a design with the two 4" flared ports to the dimensions you've mentioned above. How many ft^3 would that be?
