lildave
component speaker crossover help
first off I'll just say nice forum.. I've been lurking for a while..
but anyways.. a while ago I bought some used DD DDC6.2 and they didnt come with a manual.. They wouldnt fit in my old car but my new car they should fit no problem but I am a little confused how to hook up the crossover.
looking at it there is
+ IN - (I'm gonna assume that is where I hook the wire from the amp to)
the confusing part is how to hook up the outputs
1) W+
2) 0dB
3) -3dB
4) -
just to make it easier Ill say
a) woofer +
b) woofer -
c) tweeter +
d) tweeter -
the easiest way to explain this will be just to match things up
I'm gonna assume
1 goes with a
Pics of the Crossover maybe? Hook the tweeter positive to the crossover positive and the same with the negative. Do the same for the woofer..
I don't get what the question is.
do both the tweeter and the woofer hook up to the same negative?
I've never had seperates before
1=A
2 OR 3 = C
4 = B AND D
2 and 3 is used to attenuate the tweeter to your likeing. Like if you use it at 0db and think its to loud you can hook it up to -3db.
1=A
2 OR 3 = C
4 = B AND D
that is what I figured it was.. I just thought it would be better to ask since I dont wanna screw anything up..
