daman
help with recone
alright so i just got my recone in for another one of my 18 btls i reconed them before but this time its diferent as you can see in the pic below it has 4 leads if thats what they are coming out the spiders on each side total of eight on each side how would i solder this on im use too just two on each side
Its a little fun getting all the leads into each terminal, but the BTL terminals do have larger holes than the standard ones. We twist and shove all 4 wires into each terminal... really technical terms there;)
Leave a slight bump (meaning dont pull them tight) for a slight bit of strain relief. Solder, and trim all the excess off the bottom.
A little tougher to get into the hole, but easier to get things right.
Let me know if I can help with anything else.
Thanks,
Scott
