jaynanspl
power question
I have 2 mtx thunder 7801d amps and was wondering if that is enough power for 1 of the Bl 18's? If yes what options should I choose for the Sub? I know I'm going to need the daily option for sure, but after that I'm lost.
I would get a BTL with dual 1 ohm coils.
Ohm: Dual 1
P Chamfer: no
Cooling: yes
3rdMagnet: yes
HiXmCoil: yes
Daily or SPL: Daily
Universal: yes
You have 2400+ watts with those two amps. I would get a BTL over a BL with that much power.
Brian
like brian said the btl will handle that power nicer, pushing 2400 to a bl is a little pushy
Ohm: Dual 1
P Chamfer: no
Cooling: yes
3rdMagnet: yes
HiXmCoil: yes
Daily or SPL: Daily
Universal: yes
Brian
Why not the Dual 2?
The TA7801 makes max power at 1 ohm. Buy a dual 1 ohm sub and connect one amp to each voice coil.
Brian
