vanquish
Need a Box Design
i have an 04 honda accord sedan which im going to put a
Fi Audio 15" Q
Sealed Box
sorry i dont have trunk dimensions...
what do you guys think will i have any problems?
Design me a box! anyone pleaz
Edited by lost
should be a fairly easy fit, but we do need dimensions
crap, ok i'll have to measure it tomorrow.
sorry im a complete newb when it comes to this kind of stuff but what exactly am i measuring because my trunk has alot of places that are narrower than others.
Do i measure from surface to surface when it comes to height (hence i tried to get measurements before but i noticed the 6x9's are quite lower)
Sorry again for the stupid questions lol.
Measure the max dims...then we'll have something to work with.
Thanks!
-Nick
Thanks!
-Nick
Ok i got 36 x 36 x 18
width = 36 in.
length = 36 in.
height = 18 in.
Q15 Specs
DUAL 2
Fs: 24.9 Hz
Re: 1.4 Ohms/coil
Qms: 5.72
Qes: .54
Qts: .49
Mms: 279g
Cms: 0.15mm/N
Sd: 810cm^2
Vas: 135 l
Spl: 87.7dB 1W/1m
Bl: 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
Didn't want a box that's going to be HUGE but still works well...Hope this helps!
Edited by lost
You are looking for sealed, so it is very simple. . .
you need around 2.6 ft^3 with driver displacement. That is roughly 4500 in^3.
you can make the box whatever size you want as long as the internal legth x width x height multiplied together roughly equals 4500.
Example. It needs to be 15" high internally for the driver to fit. If you made it 24" wide (22.5" internal), then you could calculate the internal depth as:
4500 / (15 x 22.5) = 13.33 or 13.25 to make it easy.
Your internal box would be 15 H x 22.5 W x 13.25 D = 2.59 ft^3
I would face the sub rearward and double the rear baffle that the sub mounts on. Use 3/4" wood, so the external box dimensions will be:
16.5" H x 24" W x 15.5" D
That shoudl be pretty easy to follow. If you need more help, let us know.
Brian
