TooLowTooGo
Power Acoustik A3000DB amp
hi im going to another comp on the 1st (sunday).
ive been running this amp @ 2ohms with my 4 12's.
the ams specs are:
1100@4ohm
1800@2ohm
2300@1ohm
3000@ MAX
well n e way, i was thinking bout running all 4 12's down to .5ohms. how long do u think i would have b4 the amp went into protection or overheated? i called up PA and they said that they never tested it at .5ohms.
thanks.
ive seen them amps blow at .5 oh, but it was player longer then burps...
maybe if you just burping it, it might not blow...
oh and it doesnt do 3000w, 2000w is the most you might see from that amp...
plus the x-over isnt that good so be carefull
good luck
jamie
