korndawg
Quick Newbie Question
I THINK i'm set on getting the Q12 but a lil confused on which impendence to get. The sub will be powered by a Kicker ZX1000.1. Do I want to go with the Dual 1 Ohm or Dual 2 ohm? Thanks!
That amp is stable to 2 ohms, so if you're going with one woofer, you want that one woofer to come out to 2 ohms. Dual 1 ohm coils in series will work out to 2 ohms. You probably want Dual 1, if you going with one woofer. If you're getting two woofers, then two Dual 1s wired in series, then parallel will give you 2 ohms as well. But it sounds like you're getting only 1 woofer. :)
Edited by SteveSan
