bdufner
2 BTL's
Do you think 2 loaded BTL's with daily option will work with 4 SAZ-3000D's in a SPL only setup (burp). This will be a 16 volt system and box after sub and port displacement will be 8.75 cubic feet tuned to 50hz. If not what subs.
If you're only burping it, I'd forgo the daily option and get the tighter tolerance coil assembly...
Allready have subs so wondering what to do now as the subs are new.
Dont want loaded BTL's for SPL...
The Hixmax coil hurts it numbers wise..as does the cooling..
Subs are 15' BTL's with Pole Chamfer, Dual 1ohm voice coils, HiXmcoil, Daily, 3rd magnet and Universal setup. Can this be changed to SPl and no HiXmcoil, dual 1's and Universal with Pole Chamfer. Want it for best possible SPl set up. What would recone cost shiped to Glendive, Mt. 59330.
Edited by bdufner
It's not a recone man it's the motor itself...there's a good amount of steel taken out of the inside of the motors for cooling, that generally have adverse effects on SPL due to less motor strength...
Thanks!
-Nick
