mazzasec
Dual 1's pr Dual 2's
Well right now I am gonna get either 2 Fi BL or 2 ICONS. They will be wired to 1ohm off my soundstream pca2000d. But in the future i will be getting a zx2500.1. On the kicker site it rates it a 2500 rms at 2 ohms. Are the kicker amps one ohm stable? Cause if i get dual 1's to run off my soundstream amp at 1 ohm then when i upgrade to my kicker amp and not be able to wire them to 2 ohm then i got a problem. I was thinking though if i just got Dual 2's and just ran them off the soundstream amp at 2 ohms for 1500 watts then just be set for when i get the kicker amp. Or can will i be able to wire dual 1's to 2ohms off the kicker?
So what exactly is your question?
If it's a wiring related question... start reading at bcae1.com (specifically here)
You've been asking a lot of simple questions lately, and you really need to start doing some reading on your own.
my question is can dual 1's do 1 ohm on my soundstream amp and then when i get my kicker amp be able wired to 2 ohms
cause if i recall correctly dual 1's can only be wired to 1 ohm and 4 ohms
Edited by SEC
dual 1s can be wired for 1 ohm, .25ohm and if series/series, 4 ohm.
if your for sure upgrading amps in the future, grab the d2s so you're set.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
then ill probably just get the dual 2's run them 1500 watts at 2ohms on the soundstream then when i upgrade to the kicker run them at 2 ohms for 2500 watts
Edited by SEC
