wrathdchild281
2 350's and a 240amp or 3 300amp alts
Hey guys im about to purchace a triple alt set up from iraggi alts for my silverado. My question is should i get 2 350 amp alts and a 240 amp alt to help with at idle amperage or should i just get 3 300 amp alts. Ill be running 12k rms for a daily setup, thanks.
3 300's.
or if possible save up some more and get 3 350's.
well the 240 would be to help out the at idle amperage because i will be using it for daily so high rpms isnt always possible. Also why would you pick the 3 300s over the 2 350's and 240? The 2 350s and 1 240 will actually have 40 more amps total at higher rpm.
lol, i'm a jakcalope and didn't count the 2 350's correctly. what do they all produce at low rpms?
edit: haha jackalope..
Edited by fbi90909
