flakko
Sub decision once again
I'm running my options and these are to be run of the sub channel of an AX5600 (don't know the exact sub, was told around 6-700w@ 1 ohm) i would prefer the mounting depth the to be 6" and under (preferrably skinnier the better, but if it will proved better performance, im all for up to 6.5. I would like to keep the airspace around 1.5 cubic ft sealed
choices so far are (in no particular order):
1 10 or 12" SE
1 12" FI SSD
2 10" FI x1 V2
2 Soundsplinter RL-i 1
2 10" Sundown Sd1's
2 12 or 10" Mach 5 MAW 10's
for the RE's i would be staying with the optimal sealed enclosure
for the SSD i am staying with the recommended box specs of 1.1 cubes with the Copper coil + soft spiders for less power handling. Any idea on the amt of distance the pole vent needs from the side of the box? i want it to be as skinny as possible.
for the 2 10" X's im just going use .65 cubes each.
i was doing some calculations (not sure how accurate), but due to the limited xmax of the X's the single SSd would have a tad more displacement than the pair of X's.
the most expensive are going to be the 2 Sundown and the 2 RL-i's
the MAW's are cheap but they have gotten good reviews....
As you can see, i am leaning towards more SQ from my system. Im going to focus the majority of my efforts on the front stage and installation. From what the way i am leaning, its Either going to be the pair of X's or the sundowns. the other subs are either too expensive or i am not digging the deep mounting depth.
also any other reccomendations would be nice as well :)
I think the Fi X price is awesome, but I love the RL-is also. If you are considering the SSD, I would drop the SE from the list. If you calculations are correct, maybe the SSD is the best single sub choice, but you can't deny the price/performance of the Mach5's.
I was gonna ask, why you didn't have an ICON in that list.
i don't have the power for them, nor the space. going to be bout 700w at 1 ohm.
turns out i have even less space than originally planned so that scratches out the SE10 and SSD, i think im going to be one of the guinea pigs for the Sundown SD-1 v2.
They look to be promising drivers, I would love a pair. As for the Icons mounting depth, that has been the one issue a few people have had.
