bigjae1976
Enclosure size, tuning and 1 XXX 12
I've got 2000 watts to drive an RE XXX 12 - the split coil design.
What would be the ideal enclosure size and tuning for a HT setup?
For HT you are going to want to tune really low, somewhere in the 12-15hz range. As for enclosure size, I have no personal experience building a box for the xxx so I will refrain from recommending but will say with that much power you may need to downsize from the norm a bit.
2-3 cubes tuned low like sean mentioned. if the split coil design is as strong as the xbl^2 drivers thermally, it'll eat the 2kwrms pretty easily in that sized box. i threw 2.5kwrms at a xbl 12xxx in 2.5 @32hz with 36in^2 of port in car and never hurt the thing.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
im assuming the split coild is the 06+.. from what ive herd (straight form a re dealer) is they have problems with cooling do the the open air design
How big can you go? For HT, something like 3.5-4 cubes tuned to 15 Hz would be a lot of fun.
My house is 1800 sq ft ;)
4 cubes is definitely doable...sounds like a plan.
So if I go with 4 cu ft and (1) 80 sq in port, how long should the port be if I tune the box to 15 hz?
Edited by bigjae1976
