cblaze
do the new merlins have bass boost
No eq should be used for boost either, only cuts.
just depends on how high u turn it,just gotta use it wisely,its impossible to keep a class d from clippin completly
Not impossible at all. Either way boost is bad.
Care to explain?
  JimJ said:
Care to explain?
please do. i too am interested.
anyways YES it does have bass boost....but you shouldnt use it. just my suggestion
  flakko said:
  JimJ said:
Care to explain?
a class d is gonna clip at any volume,u just cant clip it to bad cuz the risk of blowing it,or the subs one,thats my 2 sense,why do u thank they made class d amps for subs,DISTORTION,yeah most likey if u go around with the bass boost up to like 18db daily somethang is gona go wrong,im not that dumb tho
i'll agree on bass boost being bad but...i am going to completely disagree with the previous statement....it is not impossible...not at all
i have fed a sine wave through my HU and checked the output on my CLASS D subwoofer amplifier, so it doesn't clip! i have seen a perfect reproduction of a sine-wave from a class D amplifier...
and there are class D amplifiers amplifiers that run very low distortion also....digital circuitry isn't limited to just subwoofer amplifiers either...there are full range amplifiers that are fully digital and run very low distortion also.... I.E. eclipse makes a full range digital that runs less than .05% distortion at rated power
SHUT DOWN
if you have it set up right...you won't have to worry about clipping.
Edited by todd.brust
Clip at any volume ??? Clip it too bad ??
Uhm
Please please please google Clipping an amplifier before posting anything else...
  Quote
Class D amps are still entirely analog :)
really?
i was under the impression that the increased efficiency was due to digital circuitry
but i was completely wrong...i was just under the impression that class D stood for digital...but had never read up on the circuitry...
i just did a quick bit of reading and learned they are more efficient because of Delta-Sigma Modulation and can be fed a digital or anolog signal...makes sense now
thanks for correcting me so i don't sound like an idiot next time :)
yeah i looked it up on wikipedia for a quick explaination
about the same as the link above but a little more brief
  cblaze said:
  flakko said:
  JimJ said:
Care to explain?
class D was designed for more efficiency not necessarily because of distortion. class D were designed more for sub because subs generally demand more power, in this case cheap power, especially people who listen to nothing but rap bass lines :P its probably the filthiest choice of class for power though IMO....overgeneralizing i know.
  Quote
Class C is a lot worse.
  JimJ said:
  Quote
I havent heard a Class C, so i neglected to mention that :). I did hear a Class T amp, it was by avionixx, it wasnt bad either.
