peedee_8
MTX TA92001 for 18" BTL fully loaded
im currently in the process of building my system using the said products in the Title..
my question are, will this amp be good if not perfect for the 18" BTL fully loaded?
is the amp stable at 1 ohm? ive seen the specs of this amp but im kinda confused cause it was only CEA certified at 2000wrms @ 2ohms. i'll be adding a Kinetik HC2400 battery using a 90 amp stock alt and a regular battery? do you think my electricals can handle my system? and lastly, im gonna jail the sub with a 5cu.ft. (net) enclosure tuned at around 30 to 33Hz. will this planned system work?
oh and btw, is that amp even good enough to work with in the first place?
i think it said that amp will put out 3000 at 1ohm correct
from what i have been seeing anyhting 2000 and over will make u happy i plan on getting 2 18s when i get back
It looks to be a strong amp that should be more than enough for a fully loaded BTL. Pay close attention to the subsonic filter settings as that can ruin things rather quickly if not dialed in correctly to the box with that much power. I have yet to run accross one of those amps, so I cant truly say how "good" it is, but Im sure its fine.
Kinetik will help things, but 90amp alt wont keep up for too long before you start to drop voltage. You will definitely need to get a larger alt to help things along if you plan on running it hard for too long. System in general should be solid (with the exception of the alt).
Thanks for the inputs guys..
I knew it! the alt will be a big set-back for my system..
but nothing much i can do about it cause thats the biggest alt that i can use for my car right now.
btw, its a 98 Isuzu Trooper.. but id still try upgrading the alt.. i might get lucky and hopefully make something work for my car..
***Attention Fi Car Audio Staffs!***
This is a notice regarding the future ordering of two Fi BTL Subs.
one 15" BTL (dual 2, cooling option, daily, universal)
and one 18" BTL (dual 2, cooling, 3rd magnet, HiXmCoil, Daily, universal).
I asked my aunt from CA to order it for me because im from the Philippines.
I believe she already sent an email to [email protected] but im worried that she might not get a reply like from what ive experienced..
Could somebody from Fi give her some assistance?
She'll be using the email add [email protected]. Hope this info helps.
Thanks!
Edited by Fi8
