hi, i am wondering which amp would be better, i will be running my front stage with one of the other and it will be active but the processor will be my hu ( alpine cda 9887). ok here are the choices: new Eclipse Xa4000 bought online so an iffy warrenty. or a B stock sax100.4b that the bottom of the amp is slightly dented but has a 1 year warrenty with sundown.
I like Eclipse stuff a lot, and most of the time it all sounds really good.
But you can't really beat Jacob's customer service and his Forum here.
It all comes down to whether you want less draw from your amp.
Eclipse is a full range class D and the sundown an AB class
So: :seesaw:
However I do not know how much the Sundown draws, maybe have to check with people using it.
So: :seesaw:
Another great point to consider. I don't know what electrical upgrades you've done, but if you want to keep the system under a certain cost, using amps that draw less current would be a wise choice.
190 alt
powermaster d3100 in rear
big 3 done in kicker hyper flex 1/0
powermaster d1200 in front
the other amp is going to be a sundown 1500d for the subs ( two 12" icons)
Edited by SouthPole1989
I like to have matching amps, and I'm a huge fan of Sundown due to their quality and customer service (Jacob = A+++), so I personally would go with the Sundown. I will admit, though, that I have no experience with the other amp.
