SouthPole1989
Alpine SPX-17REF
hi, i am looking for new speakers (i finally found someone to buy my xxx comps) and i don't want to spend more then 200 bucks and i saw the new Alpine SPX-17REF and i am wondering if anyone has any expericance with them. and also if they would take 125 rms and if they could be enough to be heard over 2 12" icons with 1500rms ported.
If you turn down the subs, sure.
JoeHemi57 has owned a set, not sure if he used them or not.
So that means your front stage isn't doing its job :)
i do have rear fill.
Then you wasted money that you could have put into the front to actually do what you want your system to do.
not really, i didn't have to pay for them.
Either way it isn't going to help those Alpines keep up.
In all reality, if you want to properly keep up with 2 15s, you will need proaudio drivers or horns, which are very efficient, that need to be installed directly on-axis. For midbass, you will need lots of cone area & available throw.
You have a ton of bass potential and it will be nearly impossible without getting really extreme. The real question is what is your definition of keeping up?
whats considered very efficient. i saw some speakers that are like 93%.
93dB would be real efficient, but that isn't the only spec you need to look at as the way speakers are rated is not standardized.
"Keeping up with the bass" is a horrible criteria for choosing speakers, IMO. You can get a bunch of $1.44 piezo tweets that'll "keep up" with the bass, but the question is will it be something you'd want to listen to? Chances are...no.
And very efficient speakers in a vehicle aren't going to go together, save for horns. Most of those high efficiency speakers you're seeing are either lying or require huge boxes that you aren't going to fit in a door.
