bdufner
4 SAZ-3000D
Ordered 4 Sundown 3000D amps that were delivered Thursday. I will run them on a 16 volt system. Also what size alt and number of batteries to use. Should you use 8 volt batteries or 16 volt batteries. What are the advantage of each.
Edited by bdufner
Call up Scottie at Powermaster, tell him that you are on Team Sundown and that he can verify that with me :)
id go with powermasters, north star, kinetik, or some odysessy batts. id def look into dual alt bracket as well. and i suggest HO alternators, as well as mean green and ohio generators
Guest zedman
I am excited for you to get your amps. will you please post pics of the install?
2 15" loaded Fi BTL's for subs if they blow than maybe 4.
If your careful they should take it fine. I have two 18 inch TC Sounds LMS 18s with 4000 rms on each and they don't see it (a small enclosure though-around 10 cube ft). I will be ordering 4 of the SAZ3000Ds as well very soon here for them :)
heres a link to the one of the videos of my 18s
the BTLS are solid woofers and are on almost the exact same scale of linearity as my LMS woofers.
good choice, if you tune them low they will still suprise you in terms of SPL.
Edited by ss-audio
