SouthPole1989
Is this enough electrical..
hi, i am going to be getting an sax100.2, sax100.4 and a saz3000d. and i am wondering if this is going to be enough electrical to support it. 1 powernaster D1200 up front, 2 powermaster d3100 in the back, a 190 amp alternator (biggest one for my car) 1/0 big 3, and i am going to be running a ground run to connect all the batteries together. also the sax100.2 will be at 2 ohm. two of the channels will be at 2 ohm and the other set will be at 4 ohm on the sax100.4 and the saz3000d will be at 2 ohm(reason for the saz3000d at 2 ohm and not an saz1500d is that i might get a new vechile(sp) in a year and then i want to go for just spl in the new vechile(sp(. so then i will already have 1 of the amps already.) do you think that will be enough electrical or should i add another d3100
Edited by SouthPole1989
southpole....
you could try contact iraggi alts for a higher output alt in case you wanna get nasty with your saz and go 1 ohm !!
I would say the 3D at 2 ohms would push a good 1700~ watts out at 13 volts.... and then some...
just a quick question on the 3000d what will it put out at 2 ohms at 13.5 volts.
~1800 - 2000 watts or so, perhaps more depending on your reactive load.
