Mega Heavy Bass
Some SPL Tetsing results for you
I thought I`d put up some scores from different sub set ups which I have tested in my standard 2.5 Cu.ft. box - 4" Aeroport tuning to 27Hz with 1x Directed 1100d amp.
Here goes:
Stereo Integrity Baby Magnum 12" in ISO: 1ohm Load / 1100wrms
Peak= 137.0dB @ 29Hz
40Hz= 134.7dB
33Hz= 135.6dB
25Hz= 136.7dB
20Hz= 133.7dB
10Hz= 127.3dB
Total ((((Propper Droppers)))) Score = 134.1dB
JBL Isobaric: 2ohm load / 700wrms
Peak= 134.8dB @ 33Hz
40Hz= 133.3dB
33Hz= 134.8dB
25Hz= 133.8dB
20Hz= 134.0dB
10Hz= 126.7dB
Total ((((Propper Droppers)))) Score = 132.9dB
Baby Magnum 12" DVC: 2ohm / 700wrms
Peak= 136.9dB @ 46Hz
40Hz= 133.9dB
33Hz= 132.8dB
25Hz= 131.6dB
20Hz= 133.0dB
10Hz= 124.9dB
Total ((((Propper Droppers)))) Score = 132.2dB
Adassa Audio 12" Prototype QVC: 2ohm / 700wrms
Peak= 134.5dB @ 33Hz
40Hz= 130.7dB
33Hz= 134.5dB
25Hz= 131.9dB
20Hz= 131.4dB
10Hz= 125.9dB
Total ((((Propper Droppers)))) Score = 131.5dB
JBL GT4 12" Normal: 4ohm / 450wrms
Peak= 135.3dB @ 46Hz
40Hz= 133.9dB
33Hz= 130.7dB
25Hz= 129.5dB
20Hz= 131.2dB
10Hz= 123.6dB
Total ((((Propper Droppers)))) Score = 130.7dB
Here are the totals in each SPL league:
((((Propper Droppers)))) - Average Totals
1: 134.1dB - Stereo Integrity Baby 12" - ISO Configuration
2: 132.9dB - Pair of JBL in ISO configuration
3: 132.2dB - Stereo Integrity Baby 12"
4: 131.5dB - Adassa Audio 12" Prototype
5: 130.7dB - Single JBL
Peak Freeqs:
1: 137.0dB - Stereo Integrity Baby 12" - ISO Configuration @ 29Hz
2: 136.9dB - Stereo Integrity Baby 12" @ 46Hz
3: 135.3dB - Single JBL @ 46Hz
4: 134.5dB - Adassa 12" Prototype @ 33Hz
5: 132.9dB - Pair of JBL in ISO configuration @ 33Hz
20Hz:
1: 134.0dB - Pair of JBL in ISO configuration
2: 133.7dB - Stereo Integrity Baby 12" - ISO Configuration
3: 133.0dB - Stereo Integrity Baby 12"
4: 131.4dB - Adassa Audio 12" Prototype
5: 131.2dB - Single JBL
((((Outlaw Bass))) - 10Hz :
1: 127.3dB - Stereo Integrity Baby 12" - ISO Configuration
2: 126.7dB - Pair of JBL in ISO configuration
3: 125.9dB - Adassa Audio 12" Prototype
4: 124.9dB - Stereo Integrity Baby 12"
5: 123.6dB - Single JBL
You can see by the results which subs or sub set up excel at low frequencies.
You can also see which subs have a higher Peak performance
And it`s a good way to see how budget stuff can outperform or nearly match even more expensive stuff, even if you have to get two subs to do it. It still costs only
Edited by Mega Heavy Bass
Wow nice job.
I`m pretty sure I can get them louder. :)
If they were in a standard ported box the Peak SPL score would probably be over 140dB+
But the ISO set up makes them play flatter, louder @ lower frequencies.
BTW: The scores are done with the mic in this position.
It`s the position I test in for ((((Propper Droppers))))
I have it there because it`s roughly where your ears would be when listening.
In the dB drag position I think it would be louder still.
When I get the chance I`ll test the system in the dB drag (dash legal position) just to see the difference...
