civicman07
15" Daily pounder
Im looking into getting a 15 for daily use. I want it to be a daily pounder that sounds good also. i mostly listen to rap music. I got a memphis 1000D to run it and im looking at either the SSD or the Q, im on a budget so not sure which one i need with what options? Moeny wise which would be the best sub for what i am looking for? Only thin i know is it has to be a dual 2 ohm. help me out thanks
I would vote for the SSD with BP power and flatwound coil.
So i can get a 15 ssd with bp and flat for 269, or i can get a 15Q plain for 279, and no option BL for 279 but im sure i would have to add some options like cooling for daily pounding, So i think the BL is out, so its between the ssd and the q, i know that the bp option on the ssd raises power handling but what does it actually mean? what is added to the sub to make it handle more power?
go for the Q with BP
Why a q with bp? wouldnt a stock q be fine sonce im running a 1000 watts? and like i asked before what does the bp option include? i knwo it raises the rms but what is done to the sub for the bp option?
