f5centvillian143
Help/recommendations for a camaro.
.............. I don't have that much $$$ flow right now and my current setup of 2 JL 10"s just aren't doing the trick. I was offered a box that holds two 12"s but I don't know the dimensions of the box (it was in an 88 Camaro) ........ I was wondering what would be a cheap way for me to get by with some good sounds........... I was thinking maybe 2 Rockford HX2's and some somewhat cheap amp............ any help/recommendations would be largely appreciated........
Thanks,
Jonathan
Idk...... maybe some Audiobahn's or something......... I'm up for any info or recommendation........ Thanks again
Edited by f5centvillian143
Thanks,
Jonathan
2 Adire Audio Shivas($125 each) http://adireaudio.com/StockProducts/raw_drivers.htm#Shiva
one JBL 600.1 ($219) http://www.cardomain.com/item/JBLBP6001
port your prefab enclosure and tune it pretty low(30ish) and you will be set.
hope this helps :D
