pimpedout97x
RF Punch150 "25 to life"
Your 1.6 comment will really depend on the speakers. If the specs are off a bit I would say no, unless they are off in the other direction. If you actually measured the 1.6 I would say you are okay, but I know you didn't and I am not referring to DCR either.
the speakers are 8 ohm, and im referring to using 5 per channel. 5x 8ohm speakers in parallel = 1.6 right?
if not, ill use 4, and get a 2 ohm load.
I believe the specs on those about as much as I believe you have an SQ install ;) I'd really measure before making any more assumptions.
what load you think they are? higher than 8? its not eminence...im selling the eminence....
how can i test, just put a DMM to the + and - terminals on the mids?
or wire up the speakers in parallel, then check the load of the 5 mids?
Edited by pimpedout97x
