Fi4Life
15" Fi BL
im lookin into buyin an fi bl, and i have an RF T10001bd amp rated at 1486 watts at 1 ohm,
would this be enough power for a daily BL
if it is wat options should i consider??
i was thinkin get just the cooling
(i also got a kicker zx1500.1 rated at 1706 watts at 2 ohms, and i would get the sub loaded w/out extreme leads)
thanks
thanks
my RF T1001BD pushes my bl 18 with no problem. i have the p chamber and flatwind coil options. get the bl loaded. the amp will kick the sub to its limits.
Extreme leads are only necessary for SPL apps only...
Do not use extreme leads if you plan on using this sub daily..
Check the FI BL options explained topic pinned at the top of this forum and you will have a better understanding...
That amp should be fine with the sub, However I recommend a fully loaded BL for headroom that way if u decide to get a better amp your sub can take the power with no problems...
