cjack
memphis, soundstream, hifonics-Btl amp suggestion
I was planning on purchasing a fully loaded 15'' btl and wanted to know if I could get a couple suggestions on what amp I should purchase. I'm looking at the 2-Channel XXV Colossus (1 x 3200-Watts....Bridged Mono @ 2-Ohms)-$660.00 or the hifonics BXi 2006D (2000-Watt x 1 RMS @ 1-Ohm)-$314.00 or the memphis mojo 16-MC2000D (RMS Power 2 ohm (Watts) 2000 x 1 @13.8V)-$880.00 or the Sound Streem PCA3500D PICASSO ( 3500W x 1 @ 1 ohm)-$480.00. The reason I ask because I've only had experience with the memphis amp and was impressed but as you can see its alot more expensive then the other amps that put up similar numbers. So if anyone could help me decided which amp I should purchase that would take advantage of all the btls power I would appreciate it. Thanxs.
well the bxi2006d i wouldent get for that sub.....
i would either go for the 2-Channel XXV Colossus or soundstream pca3500D
ever thought about a kicker zx2500.1
RF T20001bd
RF T30001bd
go here www.onlinecarstereo.com ull find the amps for a very good price
^x2
I like memphis amps, but I'd really go for a little more power. The kicker 2500 or those rockfords would be a great choice.
I had a bxi-2006d on mine and it just wasn't enough power to get it moving a whole lot.
Out of that list I'd chose the colossus or the ss.
^x2
Both of you had similar responses, then why is the memphis amp so much more expensive?
