SouthPole1989
saz1500d @1.5 ohm
hi, i have a opportinty to get 2 12w7 ( svc 3 ohm) for cheap ( 500 for both) and i am looking at an amp for them before i get it and i would like to stick with 1 amp for price and i am wondering what does the saz1500d do at 1.5 ohms and also i have a 200 amp alternator. hc1400 under the hood and a hc2400 in the trunk and it is all connected by 1/0 guage wire and the other amps i am going to have 2 eclipse xa4000 amps to give you an idea of the power for the amp. i might add another hc2400 if i can get a good deal on it,
Edited by SouthPole1989
I would say it probably does between 1300-1400 watts @ 1.5 ohms. Maybe even 1500, but I haven't benched mine at that high of an impedance.
Correct, it will produce around 1300 watts @ 12.8 volts @ 1.5 ohms.
These amps are rated at 12.8 volts?
Yes, the SAZ and SAX amps are rated at 12.8 volts.
The SAE are rated at 13.8 volts.
