viper_04649
Is this too much?
I got a viper d1200.1 and i will be running 1 15" at 1ohm. would that be too much power?
also if running at 1 ohm, should i build an amp rack with a fan?
if the rack is nessicary, anyone know any sites with some plans, or some ideas on designs, etc.
o yeah, i am putting this in a Saab 9000 hatchback.
Edited by viper_04649
Power handling will be enclosure and vehicle dependent. If you're careful with the gain and boost settings, I don't see you have a problem. As for the fan, I wouldn't use it unless you absolutely need it. I myself do not like to introduce components that may be a cause of noise. Post pics when you get it all done!
:D
Capone is running that amp to his 12" and loves it
I've got 1200 going to 1 12" and it shines.....of courese I don't crank it constantly with that. It's just there if I need it. :) Just be a lil kind to your D2 and you'll be good with that amp. :)
josh
hell yeah i do. this combo works great. and i constantly am blasting mine. i have it on my 12" sealed so putting it on the 15" would be no problem. are u going ported or sealed?
NO such thing as hitting too low...????
It will respond just like it's suppose to...accurate as all hell...
MMMM........ Small sealed enclosure...... I need help.
u don't think this will be good?
No No.... I happen to like small sealed enclosures, hence the MMMM. ;)
OR really BIG ones!!!!!!!! IB is the way for me. :D
