Rayzun
Console Sub for 07 Tahoe
I was wondering if anyone had experience with the JL Audio Stealth Box or similar products. I am considering a stealth install in my 07 Tahoe, with this as the possible cornerstone of low frequencies. I am also considering Diamond d661s component with the silk vs the aluminum tweeter. I plan on using these in the factory locations 6.5 mids in the doors and tweeters in the A panels ie the factory locations. I was also considering USD 6.5 mid bass in the rear doors also in the factory location about 6 inches behind the front buckets.
Amps (amp) are/is up in the air. I was considering a 4 or 5 channel of unknown origin to achieve the solution. Musical tastes run the gambit from Quincy Jones to Dr. John. I'm not looking to blow windows out but do enjoy a nice butt tickle now and then <G>.
If there is a DIY solution to the sub in a hidden situation that you are aware of, I would be most appreciative of the information.
Thanks in advance for any assistance or ideas you care to share.
Best Regards
R
