Bumpin300
Wiring Dual 1 ohm woofers
Every wiring diagram that I have found does not include dual 1 ohm drivers. I am curoius what the ohm load would be for 3 dual 1 ohm drivers wired in series/parallel. I know it will be somewhere between 1.0 and 0.5 ohms.
Thanks
You can use a dual 2 diagram. You just need to think about it a little bit. The 2 possible outcomes with (3) dual 2 subs would be...
1.34
and
3.
Now we need to figure out what it would be for dual 1. So now lets think, 1 is half of 2 so if we take the ohm for dual 2 and divide them by 2 this will give you what you (3) dual 1 drivers will be
.67
and
1.5.
Hope this helps you out a little bit. Same can be done for dual 4, 8 etc. Just need to think about it and you can usually work it out.
Jon
