drwang84
Replacement 8" sub meeting these specs
My Dad's Ford Expo's Mach Audio subwoofer stopped working. I will be removing the stock 8" subwoofer and need some help finding a suitable replacement for the stock enclosure.
The only sub I've found so far that meets the requirements is the MTX Thunder4500 8" :
http://www.crutchfield.com/S-BPWdxhzxcW8/c...;i=236T4508#Tab
And the spec requirements are:
# 8" 4-ohm subwoofer
# power range: 80-100 watts RMS (b/c stock amp is rated ~85rms)
# sensitivity: 86.6 dB
# top-mount depth: 3-3/4" (most important)
THANKS!
THANKS!
Found another option with this kicker comp 8" that might work:
http://www.garinet.com/cgi-bin/gkwebstore_...&LANGUAGE=e
The first punch might work but the second's mounting depth won't fit. Thanks for the input.
I wish the Ascendant Audio Assassin 8" would fit... such a sexay woofer for only $99 lol.
